[WANTED] Upper vent window bolt
1969cuda340
indy
My 69 dart has a 67 door and when I assembled the door today I found out the bolt that goes through the upper door panel has a special bolt to hold the window frame vent window
I need that bolt
Did you move the lock position? Sure looks like a 69 door. There are other differences with the 67 and 69 wing window assembly too. I am sure I have what you need...
Yes the guy I bought the shell from relocated the lock hole. The one picture is that of a 69 regulator. The 67 has the bolt that goes through that hole
