[FOR SALE] Used big block roller cam
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
Big block Mopar roller Comp cam. Used but in VERY good condition. 200 dollars plus shipping
Brand:COMP Cams
Manufacturer's Part Number:23-705-9
Part Type:Camshafts
Product Line:COMP Cams Drag Race Camshafts
Summit Racing Part Number:CCA-23-705-9
UPC: 036584081890
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 3,500-6,300
Intake Duration at 050 inch Lift: 252
Exhaust Duration at 050 inch Lift: 263
Duration at 050 inch Lift: 252 int./263 exh.
Advertised Intake Duration: 283
Advertised Exhaust Duration: 291
Advertised Duration: 283 int./291 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.660 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.660 in.
Valve Lift with Factory Rocker Arm Ratio: 0.660 int./0.660 exh.
Lobe Separation (degrees): 108
Camshaft Gear Attachment: 3-bolt
Intake Valve Lash: 0.026 in.
Exhaust Valve Lash: 0.028 in.
PM please located 35 miles NE of Pittsburgh, PA.
