kiss
I have used the search feature extensively here and haven't been able to find an answer to this question. On my 360 LA build I am going to use the Mopar performance crinkle black cast aluminum valve covers. There will be baffles in them also.
I do not want to drill holes in them for PCV and breather for various reasons. My solution for a breather is on the passenger side (rear) run one of these twist-on breathers:
http://www.summitracing.com/parts/dcc-4529880
For the drivers side (front) I need to run a PCV. The PCV will be in the front because I am running an Edelbrock carb which has a front PCV port. Anyways I was trying to see if there was a grommet that would work in place of where the twist on oil cap goes, so I can just put a PCV valve in there. I could have sworn I saw a member here with pics of such a grommet and PCV valve setup.
I searched and searched, is this the correct one?
http://www.summitracing.com/parts/sdk-c7az-6892
If that isn't, or if there isn't a grommet that will work in place of a twist-on cap for the PCV, I was going to get something like this:
http://www.ebay.com/itm/Chrome-PCV-...ock-/161654315049?hash=item25a3591829&vxp=mtr
I am hoping there is a grommet available for the twist-on spots. Thanks!
