I've read many forums on lashing valves on here and almost all of them say to do it hot. I don't necessarily mind doing that, but many old hat mechanics seem to say you can set the lash cold.
Is there any reason this wouldn't work? It seems like the suggestions I've heard for flat tappet cam engines is to:
It seems silly to do it hot/running and fight with jumping rockers and oil everywhere when the expansion of the parts should be graphable / known... wouldn't that leave you with a cold feeler thickness and a hot feeler thickness?
(okay maybe I do mind doing the lash while hot, a bit)
Why not just zero lash all the way around?
See this video from VGG :
Welcoming all opinions before I attempt myself.
- Use a breaker bar with the correct socket
- Spin push rod by hand
- Tighten (or loosen) all rockers until there's just a bit of tension against the rod
- This should get you to zero lash
- Rotate engine 90 degrees, repeat on loose valves
- Repeat until nothing is loose
- Go to all bolts and do a 3/4 turn tight - this should be the preload
