Snake
Mopar Nut
I have everything now to swap out the springs,the heads are off.So whats a good spring compressor,I want to do this myself. So whats out there,and any tips on removing the springs and installing the springs and the seals.
Yup I just viewed it Looks like Walmart sells it.
Looks high tech .I grabbed this three part tool a long time ago. It has a shaft with two Allen bolts to hold the shaft down in the saddles. The handle is a two part handle.
I made this wood board to mount the head to it and then C clamp it to the work bench.
This works on the bench or in car.
Nice Rob! Once I find time weld I want to make one like it.
That's a dandy right there. I'd have to have one like that if I changed springs more often.I grabbed this three part tool a long time ago. It has a shaft with two Allen bolts to hold the shaft down in the saddles. The handle is a two part handle.
Wal Mart sells Lisle tools. (not a made in China knock off)Do NOT buy a tool from Wal-Mart! Not when there is a good chunk of "stored energy" waiting to take an eye or tooth out.
I have a couple. The one with the red handle i'll sell. Not responsible for the damage it does. Lol
.......................the heads are off.So whats a good spring compressor,I want to do this myself. ...................
