Valve springs question
1938dodge
Active Member
Biloxi Ms
I’m doing a fresh up on my LA 318 just purchased the SPD 25 cam with new lifters and push rods.
My question is I have a complete set of P4120249 springs that have been sitting in my garage for a while now.
With this new cam and everything else being stock should I use these springs or stay with the original springs?
That spring looks to have very thick wire, meaning it has a lot of tension. I am only going by the pic.
Is the cam a flat tappet? if you want it to last, use the lightest spring that will control the valvetrain at max engine rpm expected.
with those springs rated for .430~.500 lift and the cam at .410 lift it's kind of a borderline call.
i'd err toward something a little lighter, it's not like you're gonna be revving its balls off anyway.
203°/.410 You could use a stock Melling spring. Their 340 spring is #466434 (recommended for their MTD-1 and 2 cam which is their versions of the 340 cam.)
Not sure if at your spring pressure it is that critical, but rust on a spring is BAD. Creates weak spot where rust is.
