Cythomas
Will a van 727 transmission work in my 1973 Duster? Do I need to change anything?
Thanks
Thanks
If the tail shaft is the "normal car length" tail shaft, should be pretty basic. I have a car 727 in one of my vans so... But be aware some are lock-up and suchWill a van 727 transmission work in my 1973 Duster? Do I need to change anything?
Thanks
Agree and i have used van trannys in my Dusters the only difference i found was the dip stick and tube are shorter in the van and are a little harder to reach in a car .If the tail shaft is the "normal car length" tail shaft, should be pretty basic. I have a car 727 in one of my vans so... But be aware some are lock-up and such
As long as your Duster isn't a console automatic car, the van 727 will work just fine. The truck/van 727 tailshaft housings do not have the tabs on the bottom to bolt the shift linkage to. Also, the truck/van tailshaft housings have the snap ring peep hole in the side of the housing instead of the bottom of the housing like the car housings.
Good info! The only car I ever put one in was a 71 Challenger that was a column shift automatic. I do remember it being close, but had maybe an 1/8 inch gap. I guess the upper hoop part of an E body T bar crossmember must be bigger.I had one of those tailshafts with the snap ring peep hole on the side and it hit my trans cross member in my 68 A-body.
Kept knocking out motor mounts and trans mounts until I figured it out and swapped the extension housing.
