[Found!] Vent window adjuster
I believe that is the allen screw you access via the little hole in the upper door panel . The one with a tiny plastic plug.
The screw is probably inside your door still.
Pic
67 used clip and screw
Nope part is missing as bottom of door empty except for dust. Have looked thru 5 boxes of parts that came not on car found lots of goodies but not that.
67 is different than 68+, do not recall any adjustments there. On a 67 the screw is in a different position (lower about 1") than the 68+
1967
Alan
