dartfreak75
Restore it, Dont part it!
Aight so its been about 6 days since I started and ran my car because of work and weather. Well today I got up and was mowing this morning I went to move the dart so I could mow around it without blowing grass all over it and it won't start. Im thinking cause its cold and hasn't been ran in a few days (it was like 38 this morning) so I pump the gas and try again nothing, so now im thinking well I flooded it because i can smell gas pretty strong under the hood. So I go on finished mowing went and ate and came back several hours later still nothing. I check and no spark. So I run all the tests that we covered last time and i have the exact same issue as last time. I have like 11.6 volts at both sides of the coil. So bad ecu right? Im looking at the ecu and I have like 12.3 volts at the transistor. I didn't even mean to check it I just accidentally bumped against it. So I check a bunch of other stuff and tighten my connections and check again now I have nothing at the transistor and it fired right off on the first crank. And If check the transistor while it's running it kills the engine. Like a kill switch. Sounds like a bad ground or something to me. Very weird tho never seen that before
