AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,638
- Reaction score
- 13,873
No the mount itself should not be asked to serve as the flat washer. The slots are much bigger than they need to be to just fit the bolts. They make it possible to move things around during the line-up process. If you expect the spring-washer to do double duty and act as a flatwasher;surprise! You will have fun making the point dig into the soft mount and cover both edges of the slot at the same time;remember,they are up there in a dark hole that you cannot even see the pointy spike. Furthermore it will be clamping on just two tiny crescent shaped strips of metal. When they pound out,the only think keeping the bolts from falling out, will be the loc-tite.And the mount will be free to move about, under the failed spring-washers.OK, I get it now. I need some type of lock washer that is beefy enough, and I guess the mount itself can serve as the "flat washer." Loctite will make sure it stays in, and 1" bolts should be good if I don't add extra washers. And I'll check to see if the mount is actually OK.
With the factory parts loc-tite is not required.
Scaring up factory parts may not be possible,but taking a couple of thick,large-od/correct-id agriculture-equipment,washers, over to the bench-grinder to cut one/or both sides flat, shouldn't be a problem.
The factory stuff was a strip washer,like a short length of hard flat-iron with a hole punched in the center of it, cuz of the way the washer has to fit between the sides of the "tunnel", on it's way home.
Try to imagine why yours are missing now? There may be more than one answer.......
