MrJLR
Built, not bought
Interesting
Jeff
Jeff
I was surprised.....I planned on going electric....now I'm certain!It was more than I expected. I'm sure the electric fan guys are pretty stoked.
Jeff
So what fails more often....a broken belt or an electric fan failure?
Jeff
I was wondering the same thing....although I don't it's as much as the fan...What will you do when someone does testing showing how much HP an alternator costs at full load.......chuck that too?
and to add to RRR's quote, an electric fan loads the alternator more, causing more drag equaling a little hp loss.What will you do when someone does testing showing how much HP an alternator costs at full load.......chuck that too?
broken belt is gonna be a problem whether you have belt driven fan or electricSo what fails more often....a broken belt or an electric fan failure?
Jeff
LOL..... nah, who needs a water pump and alternator.... and maybe power steering? Just keep the fan turning...broken belt is gonna be a problem whether you have belt driven fan or electric
I'm not at all saying electric fans won't give back hp, I'm just saying, if you under drive the mechanical fan, and choose the right fan, hp loss will not be 30. In fact, they got 8 of those loss horses back by just removing the shroud.
Correct. No fan "adds" horsepower. EVERY fan cost horsepower.I'll say it. Electric fans don't GIVE anything. They just don't see the parasitic drag a belt driven fan does.
It's a personal choice. Run what you want to.
I think the point was it's still a hp loss. You do NOT add hp to a motor by adding a fan. You just don't take as much hp away. In other words, you can get back some of the loss hp by different types of fans. And as I said, you usually get back more of the loss by going electric, but you can minimize this by under driving the fan and selecting the right type of fan and shroud.How much power could an alternator take to spin at full load? 80 amps at 14v is about a kW. So, even if the alternator is only 25% efficient, it's still less than 5hp. Am I missing something?
