65TerrorCuda
Bonus, pin slides right in. Wonder how that would drive
The pin could wobble inside the sleeve, it was that loose. I do have bearing retaining compound. Yeah the rubber onesIf that's a rubber bushing; Loc-tite Stud and Bearing should take care of that.
F that noise. i wouldn't be trusting no magic goop to hold that mess. those would be going straight back with a strongly worded letter and new decent ones ordered up pronto.The pin could wobble inside the sleeve, it was that loose. I do have bearing retaining compound. Yeah the rubber ones
Decided to measure and-IMHO that’s too loose to “fix” it with loctite compounds. Check the tech specs if that’s how you want to proceed, they typically say how large a tolerance those compounds are meant to take care of. There are a lot of really impressive compounds out there, but they can be very specific to their application and use.
Not sure if you’ve seen this but here’s another members list of all the LCA bushings that don’t reliably fit anymore
LCA pin loose in bushing
100% agree. Plus my magic goop is 20+ years oldF that noise. i wouldn't be trusting no magic goop to hold that mess. those would be going straight back with a strongly worded letter and new decent ones ordered up pronto.
i hear you can freeze it if you want to use it later...Plus my magic goop is 20+ years old
Loli hear you can freeze it if you want to use it later...
wait, what were we talking about?
To hell with that. It's supposed to be a PRESS FIT.If that's a rubber bushing; Loc-tite Stud and Bearing should take care of that.
The Locktite for that application.....what is it I forget.....green? It's made to help RETAIN a press fit. It's not made to tighten up a loose fit......but I'm sure you know that.IMHO that’s too loose to “fix” it with loctite compounds. Check the tech specs if that’s how you want to proceed, they typically say how large a tolerance those compounds are meant to take care of. There are a lot of really impressive compounds out there, but they can be very specific to their application and use.
the green schmoo is good to .005 and in some cases up to .015The Locktite for that application.....what is it I forget.....green? It's made to help RETAIN a press fit. It's not made to tighten up a loose fit......but I'm sure you know that.
I would trust nothing with that much slop. Reminds me of a girl I knew once.the green schmoo is good to .005 and in some cases up to .015
they do make some repair type compounds that'll go .020 but the shear is lower.
but your point still stands, some type of fit has to be there to start with. certainly not that level of kicking a hot dog down a hallway.
here's the chart, yo.
you went with charlene too?!?I would trust nothing with that much slop. Reminds me of a girl I knew once.
I think it is green. Loctite 609. Mine's dated 2005The Locktite for that application.....what is it I forget.....green? It's made to help RETAIN a press fit. It's not made to tighten up a loose fit......but I'm sure you know that.
Says mine is first generation. Even loctite charts are making me feel old lolthe green schmoo is good to .005 and in some cases up to .015
[/URL]
Good, then you use it.this is not a watch bearing.
after assembly it can't go anywhere.
Locktite 37485
About this item
- Fixtures in 10 minutes at room temperature.
- Provides 4
- 000 psi shear strength on steel.
- A high strength
- medium viscosity
- anaerobic adhesive for slip fit assemblies.
- Temperature range: -65 DegreeF to 300 DegreeF
- Typical applications: replaces set screws
- clamp rings
- snap rings
- wheel bearings
- idler shaft
- fit bearings
I highly approve of this product.
Locktite 37485
[/URL]
About this item
- Provides 4
- A high strength
- medium viscosity
- clamp rings
- snap rings
- wheel bearings
- idler shaft
- fit bearings
Interesting:Nope, those bushings are a piece of s**t.
I'm pretty well known on this site for rebuilding these Mopar lower control arms.
I use Proforged bushings in my rebuilding.
Just something to throw out to you, as a recommendation, parts wise.
Jim V.
hemi71x
https://www.holley.com/products/suspension_and_chassis/control_arms/bushing-kits/parts/115-10015
