I'm still struggling with my 340 Dart wanting to run hot. It currently has a new 3 core 22" rad, new NAPA water pump, 180 degree motor rad thermostat. It is a new rebuild using the same cam, pistons, heads and intake from before. As suggested I bumped the timing up from 10 BTC to 15 BTC. I did install a 750 Holley vac sec with a proform main body. This replaces a 650 DP.
Currently I'm running a 7 blade fan without clutch and no shroud. Will a viscous 5 blade fan cool better? The reason I'm wondering is because I want to purchase the repo shroud and viscous fan from Mancini. They state the fan is 15" in dia. My current 7 blade is about 18". So I'm guessing the repro shroud will only work with a 15" fan. I've tried making a shroud out of metal. But the fan sticks up above and below the core making it difficult to build. I'm sorry this is so long winded. Thanks Jeff
