It was set up with the msd box when I got it.probably would;nt have been my personal choice but,it's there and working so,IF IT ANT BROKE DONT FIX IT.really messed with me on start-up day.guys were coming over about 2:00 to help,so I was trying to get everything ready and checked that I could do myself.that morning I got out to the shop about 5:00 and started on some of the last stuff to get ready,installed the plug wires,coil,grease back in tranny,few other things.when I got to checking if I was ready to fire it up I checked the coil hot wire to make sure I had power.notta.No power to coil,would not light test light.started checking wires,what could be loose,what did I screw up.everything was hooked up like I had taken it apart, couldn't find the problem.one of the guys coming over was a electrical guru so I gave him a ring and told him to bring some of his testing equipment. Luckily when he got there he was driving his nova.he looked at the same stuff I had and really couldn,t find any problem,No power to coil.I asked if mayby the coil only got power on crank position and then continued from the MSD box.Well lets test my nova and see what I,ve got.same thing no power to coil with swith on,off,start to crank,or when running.think when running it showed .01 ohms or something like that.so we decided to just try to start it and see what we got.fired in less than a full rev.Still don,t understand how it works, Thanks for all your help
[/QUOTE
JD you were talking about wanting to get your engine sitting in there straight again. Quite sure that one down pipe on your headers by the starter is too close the the steering center link, that's why they have it jacked up on that side. Shimming up the passenger could push that pipe back down again, not good. So they probably just left it being they wanted headers in there real bad, and could not find a set of those nice 340 Performance HP factory cast large port exhaust manifolds.
Here is a picture of the 73 340 HP large port exhaust manifolds for the A Bodies. You can see the ones that have not been cleaned up, the HPs have much larger ports that the standard A Body V8 exhaust manifolds. Another project another time, but then you could get your engine back in there straight again and get the factory rubber engine mount in on the driver's side again too.
