So I finished tarring down the 360 that I got from a guy for 50 bucks who said it ran great but had a bad piston. He had taken the heads off and pulled the piston which had a chunck missing, I decided to take a look at the timing chain to see if it had stretched enough to cause massive predetination and caused a piston to fail. Sure enough it stretched a lot, almost to the point where I could lift it completely off of the camshaft gear.:wack: I put number 6 at tdc and aligned the timing marks with a new chain and gears. It was an eye opening sight to say the least, because the 360 supposedly only has 50k on it, I can still see the cross hatching and there is no ridge to speak of. Pics are of the old one and the new one.
