Wondering if anyone here uses E85 with an aluminum fuel cell. From what I understand, the ethanol tends to pull moisture from the air and you could get water in your system over time. With the way these fuel cells have big open vents, that does concern me a little as I don't plan on having E85 in the cell for short periods of time and draining it. The fuel will be there 24/7. With that being said, I had an idea to try and solve that problem by installing a water separator on the end of the vent line to help remove moisture from the air that enters the cell. Maybe something like a water separator for a compressor or something. The thing is, I don't that if that would work properly since those are designed to work with a compressed air system. All I want to do is try and prevent as much moisture as I can from accumulating in the cell. Anyone have any experience on this or know if that type of moisture trap would work? Throw your 2 cents out there. :happy1:
