We’re finally doing it!!
I acted as the GC on my house when I built it in 1987. I was 30 years old, and didn't know anywhere near what you do, but very successfully hired all of my subs and did as much as I could myself. I was a lineman for the power company, so I was always around new houses being built, which gave me the opportunity to see who was good in each trade and who wasn't. The relationships that I built with those folks made it easy for me to find GOOD subs who would show up when they said they would and do what they were good at doing. From the time the equipment unloaded to dig my basement until I had my CO and perm electric on was 6 months. I saved $26K over my cheapest turn key bid....but remember, it was 1987. I did the same with my detached garage when I built it in 2007 and saved even more. If I could find a good acre or two out of this bright blue county we're in, I'd do it all again at 68 years old....but might die from sticker shock comparison!
Hang in there, the rain will ease up so the wood butchers can start framing! :)
Fingers crossed, they dropped off the skylift for the trusses today. Hopefully that’s a good sign
I have been reading your entire post and look forward to it. Thank you for the break down. You should post videos on YouTube of this all. People go crazy watching home building and off grid life. I sure do. Its about all I watch. Any ways keep posting and good luck along the way
Hmm I might
Framing started today and in 6 hours, the Amish have the basement fully framed. Ground floor comes tomorrow with Roof on Wednesday and then dry in thursday
Crew couldn’t make it today due to circumstances beyond their control. Supposed to rain tonight now. So laid out some plastic wrap. Hopefully this will help save the subfloor as much as possible
Looks like some nice work. Heating system?
Propane but not even remotely ready for that yet. I have to have frame done , then a county inspect before I can have the electric done then another inspection before and after plumbing and hvac, only then will I have heat.
In the mean time, I’m brooming out the rain and snow melts. Once the doors go on, it should stop
Those I joists are nice when you have a load bearing wall in the middle like you have. Saves the roof height from being a foot or more taller if you had to clear span that width with trusses.
Yes!!! Plans called for a clear span in basement and an 8/12 roof pitch. By putting that wall in at 15 feet, we were able to drop to a 6/12. Which meant a standard truss and saved 9,000 on just the trusses
I went with full span floor trusses on mine when I built it so I'd have a wide open basement, which was my garage for many years. My roof is a 7/12 on the front and is steeper'n a mules face, lol.
Yeah, I stayed full frame I joists. They just have an extra load bearing wall now which increases the load capacity. Only down side was losing the room in attic but that let us go vaulted ceilings
Not a carpenter or framer, but are you talking about these?
If so, I've had two houses with 'em (which includes the current place), and two without. Both places that had/have 'em have creaking and sagging floors, while the floors were dead silent and level in the homes that had "standard" 2x floor joists and/or "floor trusses" (if that's the right term).
I really don’t mean to add to Duke's workload, but if this were my place, I'd cross-bridge the hell out of 'em (because they DO twist under a load), and hope like hell they don't sag and/or crack with age.
Yeah....that's what I was talking about. If you look at them from the end, they look like the letter "I". Never had any personal experience with them, just seen them used in a lot of construction on jobsites I was at for work.
