While I wait to get my 360 short block sorted Ive had plenty of time to research this particular Weiand intake and some of the plenum and runner work that can be done to it. I've gasket matched and blended the roofs about 3" in, enough so that the roof of all runners have a nice smooth curve out to the exit. The insides of the sharper turning runners were blended better. The floors only had a light pass with the sanding rolls. On the plenum I radiused all the sharp machining edges, and radiused the plenum to roof transitions as best possible. I've left the divider untouched for now as I haven't decided on carbs or what spacer, if any, I will use. Right now I'm thinking an Autoline reman 71 340 TQ (they bush throttle shaft bores if needed, unlike many other box stores) or the Demon Street Demon 750. Been reading a lot on cutting the divider down, can't find any pics of it done to these intakes. With the picture shown, about how deep and wide would you go, as a baseline start? Plenum work look good to go?
