furrystump
- Joined
- Nov 13, 2004
- Messages
- 2,625
- Reaction score
- 2,360
The glove box door. Lost the BARRACUDA script but the fish is there. The script was actually separate piece and stayed in the mold.
3 lbs in just the lid. Probably 7 lbs total with the base.
It's bigger ?Well, a problem has come to light, anyone see an issue with my 6 pack housing? Other than the air pockets.
An autoclave is not an option for DIY members here, I question the significance of the gases (or is it entrained air?) you mention that vacuum bag removes, and a compacted part is not inherently stronger by simply being thinner, actually the reverse might be true.Vacuum bag parts will increase strength, because it removes gasses, and compacts the part better.
Good CF parts are made in an autoclave, by vacuum bagging, then the chamber applies pressure to compact the fibers.
