lilredridinghoo
Hello Folks, i just trying to solve the following problem.
everytime i rev the engine past 3000 rpm i would notice some oil on the rear arch of the oil pan. under normal driving conditions there will be zero oil.
it only happens when accelerated hard and fast past 3000 or more. (like on the quarter mile)
cld it be a bad PCV valve ?
i also noticed that the oil level is a bit over the full mark, maybe this cld also cause this issue in conjunction with the windage tray ??
guess it will be caused by crankcase pressure which cld not be exhausted fast enough
okay... busted...
