moparmat2000
Finished up the welding on the crossmember filler piece today. This was what was left of the original radiator support. I trimmed it back to fit it back in above the new crossmember.
not much, going to adjust the front end height, in preparation for the front end alignment on the 19th. have guy that does front alighnments only for a living.Finished up the welding on the crossmember filler piece today. This was what was left of the original radiator support. I trimmed it back to fit it back in above the new crossmember.
I LOVE the look! Are you leaving the body as is or will you paint it? (I vote leave as is)reinstalled centerlink with new tie rods, and bought new bolts to bolt down the power steering gear box. All that needed to be removed to install some Hooker Competitions, and even then after installing the headers, it was a pain to tighten down the power steering gear box because of the limited space. Installed mini starter, clutch fork pivot plate and clutch linkage. And today, I finally took the car off of jack stands after a year of being off of the ground. Just need a few more things to fire her up for the first time.
Molasses n water. I part molasses, 9 parts water. I had to prep by removing the undercoat first. The mixture removed the paint too. I scuffed it with a wire brush after i dried it off thats about it. Part has to stay submerged, until rinse time. Stuff stinks pretty bad.That looks real nice, nothing more then a week in molasses? Good job!
Looks "Like x 3 " new!![]()
Dude, i'm jealous LoL. Really not just joking. Glad you had a nice drive. I will get there too. I am closing in on the halfway point on my project. Eventually i will be cruising around town too.Just went for a leisurely drive around town. No place particular to go, just enjoying the cooler temperature and the beautiful sunshine.
Dude that sattellite is freakin cool. Makes me want a more door B body.worked on the "B" body more door today
checked/packed the wheel bearings
inspected brake parts/ changed brake fluid
tomorrow- make a gear ratio change
getting ready for the diesel drags
6bt
