DartThis74
Very long story short, I have a mild build 360 in my Dart Sport. I was told it is an 80s model engine with no knowledge of type of vehicle it was pulled from. I had since gone through it and upgrade to a lunati voodoo (LUN-60401LK) cam back in early 2000s. Pistons bored 30 over and I had someone offer me this Mopar dual plane intake (I think part P4532058) which I installed on it. Pretty much the end of the work done on this stock engine. More to the long story, a "performance shop" offered to install a Holley HP Ultra carb sitting on the shelve to replace the old crapped out Holley I had on it, so I said why not. The HP Ultra was definitely not the right carb for this engine and I've had problems ever since as this was really meant for truly racing and wide open throttle, which this car is not at all about. I now have a quadrajet installed on the engine with a special modified adapter plate to go from spread bore to square bore to fit this Mopar intake, but of course the airflow is restricted to some extent because of this adapter. I have on hand an actual stock iron spread bore intake off an LA small block that I could swap out in place of this Mopar intake I have, but would there really be any added benefit to doing this ? Why is this Mopar dual plane intake sought after by people ? Is it really a performance enhancer to the air system over any other modern design intake ? What even type of engine or vehicles had these intakes been installed on from the factory ? Should I be talked out of swapping out the intakes I guess is my question? haha thanks for any information about this.
