Looking over the diagram it is part of the charging circui .
It's kinda hard to help you without any info on what year, and model car you are working on....
I'm behind on my crystal ball payments and the signal has been shut off.....
I've gone thru the entire Engine compartment and cleaned and replaced wires and cleaned up connectors . Then cleaned the fuse holders that were rusted . No more draining but wasn't charging that freakin wire completes the charging system and I've been killing my self going thru the engine compartment and like a dumb@ss didn't think much of this wire . I thought it was some kind of ground. I got a temp 4 gauge and will replace tomorrow see if my daughter can start cruising the Cuda .So you have the proper factory service manual. If not, you can download one here....
http://www.mymopar.com/index.php?pid=109
I would then trace the charging system wires. Put a test light between the battery and one the negative terminal and disconnect different wires until the light goes off.
If the light is on, you are drawing current...
I would first try disconnecting one of the main bulkhead connectors one at a time and then replace them until you find which harness to look in. Then zero in on it more and more until you find it....
Luckily the 65 electrical system is not as bad as some of the mid 70's cars....
Thanks for your input Krazy
I have the cluster half way out the tail lights and interior lights all work fine the problem is the reverse lights . Under the dash they tapped into the ignition for the radio and I buttoned that upWhat about under the dash?
Have you looked under the dash? Lots of do-it-your-selfers make mistakes under there. Especially when they hack in a newer radio. You never know what previous owners or mechanics have done under there....
also check any added gauges for electrical hook up.
Also what about the rear tail light wiring? Could the short be in there somewhere?
Interior light circuit?
What about the side interior lights near the back seat? Check the connector that holds the bulbs. On my 68 fastbacks one time one of the the clips that hold the bulb pushed back a little grounded to the body....
Cigarette lighter circuit?
The cigarette lighter, tail lamps and interior light circuits are "live" when the key is off (still can have power)....
Are you talking about the car's electrical system, or that your daugther will accept a credit card for making the diagrams for you? (Sorry, I could not resist...LOL.) You are really hitting this hard and my hat is off to you.and hopefully she will charge .
Strange. I can't think of any wire that could stop the starter relay from actuating by being attached, anywhere on the car. Normally, if one removes any wire on the starter relay, the car won't start. Could be something weird like a bad ground that connecting the wire provides a current path. Insure that the chassis of the car is connected to BATT-, otherwise many things won't work correctly.... Without this wire the car starts and runs fine
BTW, have you looked at the brakes? With someone so near and dear to you getting into this car, it would be wise IMO to go through that 110%, considering the condition of the electrics...... not wanting to be scary, but I can remember the things running aorund in the bakc of my mind when my son was that age.
