What front shocks with Caltracs setup (street)
highwaystar
South East PA
I was wondering which front shocks would work best with the Caltracs. I currently have the monoleafs and calvert rear shocks. I noticed the front Calvert shocks are not reccomended for street, or should I not care so much about that with 1-2000 miles a year on the street?
Any recomendations? This is a 4 spd car as well, if that makes a difference. Tires are hit a little harder typically.
The Calvert shocks are reboxed Rancho 9000's and are fully adjustable so I see no reason why you couldn't run them on the street. Adjust them for a good ride on the street and set them for the good launch at the track.
You are correct I thought they had them for the front as well. But now I don't think they do.
I'm pretty sure the fronts that calvert uses are some 90/10s that have been revalved to their specs. The rears are rancho RS9000s that have calvert stickers on em
I run the 12-way adj. QA-1 shocks on all 4 corners with Caltracs on my 66 Dart race car.Adjustment is as easy as a turn of the knob,great for quick adjustments after driving to the track.
you may have to dig on the Rancho spec sheets but i picked up some with part number 99116 for the rear and 002/003 SS springs on my 67 dart
the mount codes are L1, and you will have to measure the shock length but here is all the shock lengths FYI
http://www.gorancho.com/assets/catalog/Specifications.pdf
the fronts i called Mancini racing and got the comp engineering for the front. Will run out and check the box part number.
the mancini site suggest this part number for rancho/calvert CF42103
