moper
Ignorance is bliss, eh Rusty
"Beehive sprAngs won't do anything a good properly chosen conventional sprang won't do. It's still a valve sprAng."
You're partially correct - they do what a conventional spring does - in reality they do what a couple different conventional ones would do if you could install them on one valve - with the side affect of a lot of weight cut from the mass the spring has to control.
Had the spring materials and testing (Spintron) technology existed back then you can bet your *** they'd use them.
