I'm slightly changing the engine build in my 68 Charger. What kinda power should I expect from the following build?
440 .060 over
TRW hyperu. pistons - zero deck.
10.5:1 comp ratio
The bottom end is stock but balanced and line bored. etc.
OOTB Eddy RPM heads
Roller rockers
Hughes cam - Lift= int .548 ext .555/ dur @ .050 = 237 int 242 exh.
Headers and 3" out the back
windage tray
Performer RPM intake
750 Speed Demon carb
all the other stuf - hiflow oil, double roller chain.
also going w/ electric fan, so no fan on engine.
What do you think a 3800# Charger w/ 3.55 could do on street tires? It's a 4 speed, but lets pretend that I am an expert shifter:-D
440 .060 over
10.5:1 comp ratio
OOTB Eddy RPM heads
Roller rockers
windage tray
