There is a little lack of information I’d like to know.
Will the car see a double duty life?
X heads ported with what valves flow what type of numbers?
Who’s cam and series w/Cam duration numbers, advertised / .050.
Rocker ratio.
Car weight, tire size.
Considering you said street brawling, on the surface, between the two intakes, I’d also use the single plane. The Victor needs to be port matched & have some work done to it. Perhaps @pittsburghracer might have a picture of a worked on ported Victor? This would be a big help in finding power.
What do you have for a carburetor?
While people have laid down some good numbers with a RPM, for your description and hopefully a light car weight, I don’t think this is the intake for the job. It is a very good intake, just not for this position if I’m reading into this right.
Rocker ratio.
View attachment 1715501317 It’s a 408 stroker near .565 lift cam X heads and a 4:10 rear gear with a 727 reverse manual valve body and a 3800 stall converter.
should I use a victor intake or an rpm air gap?
