Woods74
Enlightened Senior
Please don't waste 3 pages discussing this, do a search. Plenty of info.
? What ? That trans mission # is that ?The only one that will fit is the A body OD. After that, tunnel clearance MAY be an issue. Check the threads!
HUH?!?!? What ? That trans mission # is that ?
The A833 OD is not a 3 speed. I don't know why people insist on calling it that. Anything with the A833 designation is a 4 speed transmission. The 833 OD just happens to have 4th as an OD.
The best one for you car is relatively rare. It is the 1976 only transmission, which had a cast iron case. Find one of those, if you can.
To get an A500 or A518 in your car, you will have to do some major work to the floor and to the torsion bar cross member and the transmission cross member. If you want to stay automatic, the GM 200R4 is probably the best.
Look, you are confusedA833 is a Truck trans and been told it won’t fit in a duster without many custom changes
I’m too am looking for a manual trans for my 318 duster . I currently have 3 on tree but thinking I want a 4/5 speed on floor but can’t find one that will fit
Chrysler A833 tail shaft lengths. On left is short shaft FOR ALL A BODIES. Middle is long shaft with the two shifter mounts, made in 70/ later. Front mount was used in B bodies, rear mount was for E bodies Far right is long shaft before 70 (There were no E bodies)
Trucks used long tail, and either long or short "could" be an OD or "straight" either one
I’ve been looking for that A body tail everywhere since July not seen a single one for sale anywhere
