What is this hole for?
Murray
San Jose, California
I must be getting old. Nearing the end of a resto of a '68 cuda and am fishing things through the firewall. I seem to have an extra 1" hole above the voltage regulator and behind the wire loom (see in photo). I have already run the e-brake cable, the speedo cable, clutch rod and the M/cyl. I am dumb, I can't remember what goes through this hole. Help! Thanks.
I must be getting old. Nearing the end of a resto of a '68 cuda and am fishing things through the firewall. I seem to have an extra 1" hole above the voltage regulator and behind the wire loom (see in photo). I have already run the e-brake cable, the speedo cable, clutch rod and the M/cyl. I am dumb, I can't remember what goes through this hole. Help! Thanks.View attachment 1715413205
Is that the hole for the washer hoses to pass in/out, for manual foot pump models?
This car has electric washer pump. Good idea though- should there be a rubber plug there that I just don't remember?
Thanks for the help guys. I have saved all of the plugs, so I will find it. You're the best.
