I happy just to have a reach around any more
Picking hammer toolHere's something I never knew existed until this morning. This isn't mine, but a picture from the internet. I know some of you will know what it is!
There aer also version made out of vise grips. Then later you find out that its better to butt-weld in most cases..Right again! Also punches holes for rivets or plug welds. I'm actually really excited to use this one.
Not a clue, but I see what looks like a zip tie. So maybe that shaft "jacks" back and forth without the zip tie? Almost looks like an exhaust expander.
I cant believe it hasn't been identified by now. Ill let it roll.
Bullseye pick.Here's something I never knew existed until this morning. This isn't mine, but a picture from the internet. I know some of you will know what it is!
You mean I actually stumped yall with this? You want me to tell you what it is?
Sure....You mean I actually stumped yall with this? You want me to tell you what it is?
It's a connecting rod splitter. When rods are resized and rod bolts are replaced, they are married together and difficult sometimes to get the caps off. That tool makes the job very easy.Sure....
And here I always used a ball peen hammer, dangIt's a connecting rod splitter. When rods are resized and rod bolts are replaced, they are married together and difficult sometimes to get the caps off. That tool makes the job very easy.
Proform Parts 66773 Proform Connecting Rod Splitting Tools | Summit RacingIt's a connecting rod splitter. When rods are resized and rod bolts are replaced, they are married together and difficult sometimes to get the caps off. That tool makes the job very easy.
Close, yes, .017" feeler attached, open end 1/4"...box end 7mm...Looks like a folding, pocket sized breaker points adjusting/ignition wrench with feeler gauge?
Indicator for endplay or runout..Ok! Help !! Mikie ain't got a clue
Valve adjuster ?View attachment 1716409469
Other blade is flat-tip screwdriver, w/a corner chipped..
Run out...the little ballIndicator for endplay or runout..
