What one should I buy
340six
King Of Bling
New Orleans
https://www.amazon.com/dp/B0D25FRT39/?tag=fabo03-20
or
https://www.amazon.com/dp/B0CRZ1VLTK/?tag=fabo03-20
I lost some tools to theft and non return on others. But
Andvwant to replace bearing and seal driver's
Soni don't need to make do wwith sockets and stuff.
hould i get thee 10 or 43 pieces set? Just rear end axles seals, rotor bearings seals, timing chain seal very basic. I loaned out my set and never got it back along with other thing's.
I am.now at the point I dint need professional grade, just use now and then, so can get by with a lower quality set fir every now and then use.
I've literally never used either. You got a socket set dontcha?
i have the hazard fraught version of the first one-- at least the discs are the same color-- and not found much in the way of wanting more. that being said, the first set has way more so that would probably be my choice.
