I have the springs relocated inboard so I can squeeze a set of 27560R15 tires under my dart. Can someone who has done this let me know if I have to buy a shorter rear shock?
Need a shorter shock if the axle bottoms out on the shock before it hits the bump stop on the frame. If the axle bottoms on the shock, it bends the rod, hydraulic fluid leaks out the seal leaving you with a shock in name only.
