DustyEd
Here's my dilemma ....I want to check the valve lash on my '70 duster 340, but don't know what gap I should use. As far as I can tell, the factory cam was a 276/284/52 high lift, high overlap, long duration. However, the previous owner changed this stock set up to an even longer duration cam, adjustable rockers and solid lifters back in 1975. He doesn't recall the cam specs or even the brand of cam.
So, what is the "best educated guess" for the lash gap in this situation? And, will the intake and exhaust gaps be different?
I know there's not much to go on here, but it's all I've got!
