Whats the proper way to install gas filler tube?
pauls340
17 miles N of Detroit
On a 71 Demon, does the filler tube go in thru the hole in the fender or does it get attached from the inside? Thanks
On my '72 and '75 Dusters it goes through the fender first.
C
It should go from inside the trunk. Lube the outside of it up it up with some WD-40,along with the inside of the seal,and push it in.4 screws on the outside attach it.Careful on the screws,you can strip them.
