What's up with the LA Dart engine?
HemiOrange340
Active Member
Austin, TX
Today a buddy of mine told me about something called an "LA Dart" engine.. which was a lighter weight version of the 340 you could have ordered. According to him the numbers on the engine start with "A" in stead of some other letter and that's how you can tell one from a regular 340. Being a Dart guy, I was suprised I hadn't heard of any of this and I kinda doubt that's it's entirely true. Far as I know, there was only one 340 available, at least on my 70 Swinger.
Can anyone shed some light of this for me?
Corey
You got it HemiOrange, you didn't see anything about it because I don't believe it exists. The only lightweight cars Chrysler made were the ALuminum body cars, the SS/AA Darts and Barracudas, Feather Dusters and now the Challenger.
Your friend is confused. The LA engine in your Dart is indeed lighter than an A engine. However ALL 273's, 340's, 360's and 67-up 318's are LA engines. The A engine was the polyspheric head engine, which dates to the late 50's, and was an economy outgrowth of the early Hemi.
There was a T/A version of the 340, but it was slightly heavier, and never installed in a Dart.
don't forget the all aluminum slant 6s. i guess they sorta count.
Nope. They made a Dart Lite, too. sister to the feather duster.
Right, but the design started wit the 273 in 64, then the 318 in 67, ect.
Could it be your friend was thinking of both ( engine & body ) and got them combined ?
Found some interesting reading at Wiki.
Dart Lite
In response to increased interest in fuel economy, Dodge offered the Dart Lite fuel economy package which weighed at least 150 lb (68 kg) less than the ordinary Dart Sport.[29] The 225 Slant Six was the only available engine, equipped with an aluminum intake manifold for the first time since 1960 and a specially calibrated carburetor and distributor. Bumper reinforcement brackets were aluminum instead of steel, while the hood and trunk lid bracing and inner panels were also aluminum. The Slant Six engine block had already been modified for reduced weight in 1975; in the middle of 1976 production its crankshaft was changed from forged steel to lighter cast iron. The high-flow exhaust system included a dual-biscuit catalytic converter, a 2¼" headpipe, and the muffler used on V8 models. The Dart Lite was equipped with a 2.94:1 rear axle rather than the customary 3.21:1 ratio when the car was ordered with a three- or four-speed manual transmission. The A833OD overdrive 4-speed manual transmission housing was made of aluminum. Like all other Darts, the Dart Lites with automatic transmission came with a 2.76:1 rear axle as standard equipment.[29] The Dart Lite with manual transmission was rated by the EPA at 36 mpg (6.5 l/100KM) in highway driving. The Plymouth version was the Feather Duster.
http://en.wikipedia.org/wiki/Dodge_Dart
CORRECT! I have a 64 Dart 273 built and sold in aug 63 in so cal.
I am the 2nd owner.
And the early A 318 poly used a B size 727 trans too
No it didn't. The poly engine used the same bellhousing bolt pattern as the LA.
SS/A Darts and Cudas were not aluminum. Bodies in white were shipped to Hurst where the Hemi and a fiberglass front clip was fitted.
Some of the 64 and 65 SS packages had aluminum front fenders and hoods, but that was it until 76 with e Feather Duster and Dart Lite. But in all cases the unibody began as a production unit pulled from the assembly line. Many racers acid dipped the unibody to lighten it, which caused premature corrosion. This is why few original SS cars survive today that haven't been rebodied
there was an all aluminum 318 made, block/ with heads several were made but did not make it to production. one is out there in a roadster. Not sure what this has to do with the OP LOL..
Sorry C130:) You are 100% correct I had a brain lapse and recalling my old 57 Windsor with a hemi in her. ugg man I am loosing it!
Poly 318 "A" Engines vs. LA 318 Engines
Polyspherical (or Poly) "A" engines first appeared in 1956. The term refers to the design of the cylinder heads, all of which had canted valves. The valves were also arranged so that all of the same type valves were on the same side of the head. Their basic block design was very similar to the early Dodge Hemi and Poly blocks, but no parts interchanged. Although the Hemi heads were superior breathing heads, they were heavy and more costly to manufacture, so Poly heads were developed across the Chrysler model lines as a cost saving measure. In the Chrysler and Dodge divisions, the Hemi blocks could be interchanged with Poly blocks and vice-versa.
The lower priced Plymouth line never received a Hemi engine because it never offered a V8 prior to the 1955 model year. By November 1954 when Plymouth's first V8 was introduced in the 1955 models, Chrysler was planning to phase out the Hemi design. Because Plymouth had no V8 of its own, 1955 model engines were actually Dodge Polys supplied by the Dodge Division. The displacements were 241 ci and 260ci, and they developed 157 HP and 167 HP respectively.
The first Plymouth-designed V8 appeared in 1956 with a 3.74" X 3.12" bore and stroke, displacing 277ci and making 187 HP. It was very similar to the Dodge design, but it had a longer block for better cooling between the water jackets, and larger valves requiring redesigned heads. For 1957, the 277 was bored out to 3.91" to produce 299.6ci (actually called '301' by Plymouth - probably to avoid confusion with the Chrysler "300" series cars). Also in 1957, the Poly 318 was born by changing the stroke of the 301 to 3.31, for a bore and stroke of 3.91 X 3.31, and a displacement of 317.6ci. 1957 Plymouth Fury models got a dual 4BBL 290 HP 318! Poly 318 engines were phased out of passenger cars after 1966, but were used a few more years in some truck, school bus and industrial applications.
Employing a new lightweight casting technique to save weight, the design of the Poly 318 block was later used for the LA 273 engine which first appeared in compact A-bodies. As a result, the Plymouth 277 "A" engine is the direct ancestor of the entire LA engine family, the Magnum family and even the LA-based Viper V10 engine.
Below are the differences and similarities between the Poly "A" engines (hereafter referred to as "Poly"), and the newer LA engines.
Differences Between Poly "A" engines and LA engines
• Heads are very different:
o Intake and exhaust arrangement for the Polys is I-E-I-E-I-E-I-E, where the LA/Magnum arrangement is E-I-I-E-E-I-I-E.
o Poly valve arrangement is canted with intake and exhaust valves angled opposite each other, while LA valve arrangement is wedge style with all valves aligned in a row at the same angle.
o Poly heads have the intake valves on one side of the rocker shaft and the exhaust valves on the other side, while LA engines have all of the valves on the same side of the rocker shaft.
o Poly and LA Rocker arms are different.
o Poly heads are much heavier than LA heads.
• Valve covers are different:
o Poly valve covers have two bolts in the middle of the cover. LA covers have five smaller bolts around the outside edge of the cover.
o Poly valve covers are also scalloped at the lower edge, while the lower edge of LA valve covers is straight.
• Pushrod angle is different. Poly 318 blocks had the original 59 degree lifter angle to work with the Poly heads, so the pushrods are much closer to being in line with the lifters than in LA and Magnum engines. Because Chrysler carried over the basic Poly block design with different head designs for the LA and Magnum families, the pushrod angle is much worse.
• Poly blocks are different (although they will accept LA heads):
o Poly blocks have deeper reliefs on the intake side of the deck to clear the straighter pushrod angle required by the Poly heads.
o Poly blocks are a bit heavier due to their non thinwall castings.
o Poly blocks can sometimes take up to a .130 overbore - much more than LA blocks.
o There is a possibility that one bolt hole in the bellhousing area may be a little different on earlier versions.
• Poly and LA camshafts are different due to the different valve arrangement
• Poly lifters were solid. Except for early LA 273 engines, all LA lifters were hydraulic.
• Poly "A" Pistons are different due to the different cam timing, so the valve reliefs are in the wrong places for LA engines.
• Intake manifolds are different
• Exhaust manifolds are different
Similarities Between Poly "A" engines and LA engines
• Poly "A" blocks can be used with newer LA and Magnum heads.
• Transmission bellhousing bolt pattern is the same.
• Crankshafts interchange with 273/318 and internally balanced 340 LA engines.
• Oil pump and distributor drive shafts are the same.
• Oil pans from 273/318/340 LA engines will fit
• Dampers from 273/318 and internally balanced 340 LA engines will fit.
• Distributors from all LA engines will fit.
• Poly timing chain and sprockets are the same as LA engines.
• Poly block deck height, bore spacing and 59 degree lifter angle are the same as LA blocks.
Will Poly Heads Fit an LA Block?
Because of the deep reliefs required in Poly blocks for the straight Poly head pushrod angle, it is not certain whether Poly heads will work on LA blocks. Poly heads definitely won't work on Magnum blocks, because they are oiled through the deck, and Magnum blocks usually don't have the required oil passages.
Poly Aftermarket Support
There is not as much aftermarket support for Poly engines as with the LA and Magnum series engines, but a few manufacturers are now offering parts for them - notably TTI with their excellent headers. They are not cheap though. The Poly engines will also accept the 4" cranks, which are now the rage with the Poly enthusiasts. Properly set up, they can make some serious power.
Sources:
• How to Build High Performance Chrysler Engines by Frank Adkins
• Small Block "A" Engines - Mopar Performance Parts
• Polyspherical Engine Association
• 1962 to 1965 Mopar Site
• Moparts members Dogdays, Supercuda and Hotroddave40
• Farley's member Patrick
Photos:
• Poly vs. LA valve arrangement (Poly illustration courtesy of Small Block "A" Engines)
• Hemi vs. Poly vs. LA Head Design Comparison (Contributor unknown)
• Poly 318 Valve Design (Courtesy of Chrysler Corporation
• Poly 318 in a 1964 Dodge (Contributor unknown)
this is a great post and explanation.
Your reading it wrong. He asked about a light weight version of the engine itself. Not the car. No lightweight engine version existed. Just the standard LA 340 engine that weighed the same all through it's run. Except the T/A 340 which weighed a fraction more due to thicker main webbing.
There are numerous "old wives tales" floating around just like this. They are just that, "old wives tales".
Sources:
Photos:
Yours is the most accurate article of the bunch. One small nit though....the cranks don't all interchange. Some will with just a rebalance but others won't at all, or at least without more serious changes. The '64-7 273 crank has a smaller pilot hole for the torque convertor than the other LA engines so you'd need a custom one built or a bushing added as the case may be. Also the '61 and earlier A engines have an extended 8 bolt crank made for the early cast iron torqueflites. They will not interchange with the '62-up aluminum torqueflites without some serious mods.
Thanks, Mark
The '64-7 273 crank has a smaller pilot hole for the torque convertor than the other LA engines so you'd need a custom one built Thanks, Mark
yeah but they still have the same large outter flywheel pilot ring, so just grind out the inner diameter convertor register of the early 273 crank for the later convertor snout.
fwiw
fwiw
Maybe machine it on a lathe or center drill it somehow but there would be no way to use a hand grinder and keep the hole centered. If it isn't centered, it will vibrate. It would be better to just have a convertor made to fit.
Am I missing something here? If the early 273 crank is being used in a later model vehicle, use the converter for a 64-67 273. Any reason that you can't do that?
