So I'm in the process of putting new wheel bearings in my 73 dart with front disc brakes. I'm at the point where I'm putting the spindle bolt on the hub.
What I did was tighten and loosen the nut while turning the wheel, I did this a few times. I then tightened to 70 inch pounds and backed the nut off so I could put the cotter pin in. I checked and there is no play in the wheel.
Is this procedure correct?
