Wheel cylinders
FISHYPETE
Minnesota
Need to replace the 4 front wheel cyl on my 1959 Fury. What brand is best, heard some are better than others…..Thanks
Just rebuild them. It is easy as long as you can get the bleeder screws open without braking them off.
You will probably have to search for parts, but I am sure they are still out there. My first car was a 61 Belvedere, and it had those same style brakes, but back in the mid 70s parts stores still carried them.
Thanks for your replies. They are available but my question is what brand is best. I have heard some brands are better than others but I can’t remember which
If you intend to keep the car, have the factory wheel cyls s/steel lined. They will NEVER rust again....
Fishy Pete ,
Thanks to toolmanmike’s alert , I will P.M. you —- 1959 is the changeover year —- there is an early and a late —- and I have them both —- new fresh stock —- made in the U.S.A. ….
I will go over the difference with you…..
Thank You , Toolmanmike…..Craig…..
