Wheel makeover
Magster65
Saanichton BC Canada eh.
I'm about to do a major overhaul of my Dart and I'm not sure what wheels / look I want yet. It's going from sbp to bbp and I didn't have any wheels to put on it until I figure it out. So I found a set of inexpensive rallyes. Wire brush, 80 and 120 grit got me here. Plastikote 2 heavy coats of sandable primer, silver wheel paint and clear coat (great product). Cheap and about 4 hours work. They're not perfect but they look pretty good I think.
View attachment 1715153052 View attachment 1715153053View attachment 1715153050 View attachment 1715153051
Damn, they look good! 14" or 15"?
The tires had this brown waxy, dirty staining on them that soap wouldn't touch. Pressure washing sort of worked but made them look blotchy. I tried some of that 'super clean' in the (purple jug diluted 4 to 1)... miracle product for tires! A bit of no touch and they look like new.
So happy with that I rewarded the wheels with some small center caps.
Mission complete.
I've always liked the knockout center ones on the top. That's what is going on my car eventually. My car is a '75, so more correct for me? PM me if you are looking to sell?
wow, those wheels look new! How did you get the rust in the seam out? Thick primer, sand-paint and clear. Smoooth! :eek:
I just used an old knife and this dental tool thing I have... like a seal pick. You just just have to scrape out the loose stuff. Lay a little extra primer / paint in the crack there to seal it up but don't put too much material on them. In the end I sanded almost all the primer off again but left it in the gouges and pitting. I find that thick coats of paint will chip way easier than thin coats.
It wasn't difficult... take your time and I'm sure you'll be happy with the results! :)
