wheel spacers
I used a set of 1" spacers(billet ) from ez accessory they bolt to the hub like an adapter. 5 on4 to 5 on 4
70 E-body with a .080" spring relocation. I think i might need just a little bit more spacing from the leaf as well as the factory wheel tube
This pic is with my old SS Spring and a 26x10 slick on a 8" rim
have new rim that are 10" wide and a 28X10W x15 slick i'm trying to shoehorn in without modifying the factory tubs or wheel well opening.
my math says it will fit but i might have to cheat it with a 1/4 or maybe a 1/2" spacer.
10" wide wheel with a 7.5" backspacing.
I used standard aluminum spacers from companies like Speedway and Day Motorsports on my race truck. Lots more strain than any street car and never a problem.
Digging up an old one here. What lug nuts are you using on the ez accessory adapters? I have the same ones for the rear but the stock lugs, not being bulge style, dig into the spacer with the corners of the hex. I picked up bulge style but now they sit too high, above the 1” adapter.
Wow... Is it a 1970 Barracuda Gran Coupe with a 'Cuda hood? Is white the original color?
@273valiant : I also have a 1" adapters/spacers set from EZ Accessory on my '71 Demon and I use original steel wheels lug nuts. They don't protude from the adapter, so no issue with the wheel installation.
original white paint. No, came with flat white hood. yes Grand Coupe with floor and over head console.
I have owned it sence to early 80's
kinda part of me.
70 E-body with a .080" spring relocation. I think i might need just a little bit more spacing from the leaf as well as the factory wheel tubeView attachment 1715308750
I shoe horned my tires in too, I make my own spacers out of what ever alum. sheet I need .
