When hardened valve seats production??
Just a little technical clarification. Mopar used induction hardened valve seats. The hardening only goes a few thousanths of an inch deep. Once the heads have had a valve job (seats ground), the hardening is gone. The only cure to get hardened seats back is to use replacement seat inserts, unless you can find a shop that has the induction equipment.
It is my understanding that many cars prior to 1975 were produced with hardened seats since manufacturers knew the unleaded mandate was coming and those cars were going to be subject to the rigors of running with unleaded gas.
They didn't want a bad rap when those cars that were only a couple of years old started having problems due to the unleaded gas. Just my .02. Dennis
Yes, they could have come out with the hardened seats early.
According to the 72 DartDemon Owner's manual, /6 engines were designed to run on unleaded fuel. (V-8s were not included). The 73 Dart Owner's manual stated that all engines were designed to run on unleaded fuel. I infer that these are the model years when hardened valve seats were installed on the various engine lines.
ALL 1972 Chrysler engines were designed to run on LOW LEAD fuel...its in every owners manual
Just for Information, my machinist with over 30 years experience, building engines told me that the originally Installed 1960's mopar seats are harder than any ford or chevy seats at the time. And, any new seats he would order for my engine today are no better than the original factory seats made back in the day.
Your machinist is probably just full of interesting fairytales like this.
don't waste your money unless the seats are bad.
It is foolhardy to build a pre-hard-seats head without installing hardened exhaust valve seats.
I remember reading a mopar Direct connection magazine article in 1988 where Chrysler tested all the mopar heads, and engines regarding seat wear with unleaded fuel. The results were, on Heads run during the 60's and early 70's, that hardened seats were not necessary unless you exceeded 85% of the RPM band, 85% of the time.
I think you might not be remembering quite as accurately as you'd like. To answer the OP's question: induction-hardened seats on the Slant-6 for '72, and the V8s for '73. See here for it straight from Chrysler's mouth, and if you want (a lot) more detail, Chrysler put out an engineering paper on the subject, published through SAE, quantifying the exhaust valve recession which—despite your machinist's imagination—happened when unleaded gasoline was used in stock Chrysler engines without hardened seats.
Chrysler did put even harder seats in later,(1972) because of Increasing emissions standards.
No, they hardened the seats because it was necessary for adequate durability with unleaded gasoline. Hard seat or unhardened seat does not impact an engine's emissions characteristics.
In contrast,Ford didn't even put seats in their engines in those days
All engines have valve seats. That's the machined hole where the valve...seats. It's usually machined into the cast iron that makes the head (or block, on a flathead engine), and Chrysler stayed with that inexpensive and perfectly adequate method even once unleaded gasoline made a harder seat necessary -- they just began induction-hardening the exhaust seat.
lead was added to prevent pre- detonation in 1914 or so
1923.
and valve lubrication was a side benefit.
Lead has never provided a valve "lubrication" function. The only lubrication the valves need is where the stem goes through the guide. That's handled by engine oil, restricted to a small amount by the valve stem seals.
What lead did, as far as the exhaust valves were concerned, was provide a buffer/cushion effect. The exhaust valve gets superheated by the exhaust flowing through it. With an unhardened exhaust valve and seat, once the valve closes, it and the seat can micro-weld to each other. Then when the valve opens next, the metal pulls apart like taffy. This roughens the meeting surfaces, and they become quite abrasive. The pounding/turning of a valve with such "pulled" metal on it creates a nice grinding wheel effect on the seat, grinding it down so the valve sinks lower and lower. This is valve seat recession. In addition, the roughened surfaces no longer seal against each other properly, which eventually allows still-burning combustion gases to flow through the "closed" valve, causing a blowtorch effect on the poor valve and depriving it of any prayer of a chance to cool while it's on the seat. The blowtorch effect rapidly deteriorates the seal further, snowballing the seat recession. Lead halides act as a buffer (a physical "cushion" barrier) to prevent this happening.
Very little lead is required to prevent the localised welding and taffy-pull-apart effect that leads to the abrasive surface which, through incidental or positive rotation of the valve, eventually grinds down an unhardened seat. The majority of the lead was in the fuel as an octane booster, that's all. It was widely used because it was a very cheap and very effective octane booster. It also made a crapmess of the inside of an engine and (oh yeah) poisoned us and brain-damaged our kids. We're well rid of it. If that means having to spend an extra $100 in the course of a head rebuild to have hard seat rings installed, well, yup, I'm gonna do it.
chrysler did a flame hardening of exhaust seats around when cat converts started being used , but the ind engines or truck hd got them earlier .
