jimjimjimmy
lobsterman
like most things these days someone who has nothing better to do but complain about something or gets offended and all of a sudden it's gone for ever .Yeah, what happened to the Xs?
I will have to say I am guilty of this.Way back in younger days.Gas mileage came up, and he commented he was running a 2.76 gear, and when he got to where his was going, he would just swap it out and "Chunk" it in the trunk.
Yup those were the days! LOLI will have to say I am guilty of this.Way back in younger days.
Home was Pa.School was Denver Colorado. Would swap in 2.94 for the 1600 mile drive.
Swap in 3.91 once at my destination.On the ground. 4 times a year during school breaks.
Being 17-18 never thought twice about it. 70 340 4 speed Duster. Do the tall tire thing too.
Yep,did that too, many many years ago. Changed from blown out glass packs and a 4.56 posi, to 3.08s and (genuine corvair) turbo mufflers, on my 57 Chevy (corvette fuel injection on a 360horse 350) and back again. Exhaust and center section in under an hour. The gear change difference was startling. Either direction.I will have to say I am guilty of this.Way back in younger days.
Try the pumpkin from a Terex TS14 scraper. We found that if the transmission failed it may have been caused by a broken tooth in the differential. This required pulling the pumkin out under the scraper and usually in a ditch after it had rained. Crawl under with the wrenches required, a scraper and a tube of RTV sealant. You do not want to drop the diff in the mud, so when you get it out you rest it on your thighs while kneeling in the mud and 6" of water. Inspect the gears and if OK scrape the sealing surfaces and apply RTV and lift the pumpkin up into place. Snug up nuts at 10 and 2 locations. Now try to crawl.out and get your legs working again so you can finish up.Big Heavy Chunk of Iron.
If you ever laid on your back on a creeper and tried to drop one out, yeah that's a heavy "Chunk".
Was just wondering today but the average pig weighs?Pig is my Mopar up bringing nomenclature too. Also the older I get the heavier they get !!! IE PIG.
Ok ....personal pet peeve. It's always been a chuck and I started seeing people refer to a removable third member as a chunk. Where did this come from? WTF is a chunk?
Big heavy 'chunk' of metal? Don't think I've ever called it that....Ok ....personal pet peeve. It's always been a chuck and I started seeing people refer to a removable third member as a chunk.
Where did this come from? WTF is a chunk? I've always thought that people were just misinformed but now it seems like chunk is ok. It's a chuck no?
Destroyed into chunks.....
No Sh*t. I used to lay on my back, place a 4 speed on my chest, shinny and scoot under the car and lift/wiggle it into place. At 75, that isn't happening now.A long time ago I was able to chuck that chunk in by myself on my back. But now I need my good friend Jack to help me get it back in. He helps me a lot now.
Me tooPumpkin,
The first member is the engine, the second is the transmission.
Members of the "powertrain".
Probably because the left coast has their hands on each others junk. and they are wishing for a chunk.Did you notice that most responses are right coast?
Nice try. You say it like it's truth. Very convincing.
In the context of a "third member" differential, the terms "first member" and "second member" refer to the two axle shafts that connect the differential to the wheels. The three "members" that make up the axle assembly are:
- The first member: The first axle shaft.
- The second member: The second axle shaft.
- The third member: The center differential section, which powers the first and second members.
It was explained to me by a porsche mechanic who also explained that in a rear engine porsche, the third member actually precedes the second member.
