Caliscamp72
Mostly sane GM Destroyer
No doubt about that !!!! Completely worthlessBurn the Haynes book.
I agree one thousand percent with this post , spoken from someone who obviously has installed one with proper results . Ain't it grand when a plan comes together.I installed the express kit and never referred to the factory diagram. I recall that on the column, I tested each of the 5-7 wires in all key positions...ign 1, 2, start, run, etc. To make it easier I made a small chart with wire colors on one side and key position on the other axis. If a wire had power in a particular position, I put a (+) in that box...if there was no power, I put a (-). I'd be careful about trying to follow the factory diagram as that may lead to confusion or assumptions that may not work out. I called RF once while I was installing and they were very helpful if you get to that point.
Did you get the car started? If I recall correctly, after the first bag, you should be able to start the engine. I followed the instructions bag by bag of wire in order.
My bad you counted right .... Statement as to colors still stand tho. Sorry I miscounted your postHey hold up ... I'm looking at your pics ... You counted 4????? I can obviously see five .... Not to mention that's pretty much the minimum you will see on any factory ignition switch . Black will be accessory voltage supply .
Blue and brown are ign 1 and ign 2 as far as I can predict ... You will see that one has voltage or continuity in crank position the other has voltage or continuity in run position .
That being said I don't think the factory wiring diagram would identify the function of the wire on the switch but just them going to the switch.
Alan
I have for a great many years, my 67 book only shows wires going to the ignition switch but does not define their function, likewise with the wiper switch. At least with the wiper switch there is more information in the service section. The only way to know what each color on the ignition switch does is to ring it out, following the wires helps if you understand the functions.So, I guess this means YOU HAVE NOT ever bothered to look at a factory service manual?
"From the top"GEEZUZ KRIST PEOPLE. I'm an old man and when I started screwin with this stuff THERE WAS NO INTERNET. THERE WAS NOT FREEKIN TEAM TO ASK "for free." YOU FIGURED IT OUT ON YOUR OWN or WENT TO THE DEALER AND BOUGHT YOURSELF A SHOP MANUAL
HERE is the 73 shop manual. No guarantee it is quite the same, page 8-156:
http://www.mymopar.com/downloads/servicemanuals/1973_Dodge_Body_Service_Manual.zip
and
http://www.mymopar.com/downloads/servicemanuals/1973_Dodge_Chassis_Service_Manual.zip
From page 8-156:
See the oval that says "CI-5" That means Connector, Instrument, number 5. Now wander back to page 8-168 and that will have a diagram of what the switch connector on the pigtail looks like
Totally agree on all points... Especially there are no dumb questions . We are all definitely trying to help . " dried up like one of those cellar spiders ". That is too funny ... And accurate!A $3 test light will tell you what you need to know without having to follow factory wiring diagrams. For the purpose of installing this kit, it doesn't matter what wire does what on the old factory harness. All that matters is what key positions you have power or don't on the column wires and match that up to the RF kit by function. If I recall correctly the instructions in the column wiring bag even state what harness wire requires power in a given key position (don't make me walk down to the garage and fetch my instructions ). If you ever do end up calling RF wiring for tech support, that's the info they will be looking for to better help you. I want to "see" the power and verify, but there's more than one way to do it I suppose. Like Cali mentioned, with my column, I had to fuse two of the wires together (running MSD box). If I had tried to figure that out with a FSM, I'd still be in the garage be dried up like one of those cellar spiders in the corner. It's good you are asking questions and there are no dumb questions. Everyone here wants you to succeed...and you will.
Great info of which I am totally aware and which it seems we both can utilize properly . Problem is most people starting out cannot utilize wiring diagrams and even some service info due to experience level."From the top"
S2 is the yellow start wire which goes through the bulkhead connector and ends up at one of the "push on" flag terminals on your starter relay
Q2 is the ACCESSORY wire is hot in both "run" and "ACC" and feeds power to the ACC buss in the fuse box
J2-12DBL (Dark BLue) is the "ignition run" or IGN1 and is ONLY HOT in "run"
J3-12BR (BRown) is the resistor bypass circuit (IGN2) and is hot in "start." THIS MUST BE CONNECTED to ign run (above) if you run an ignition not using a ballast resistor
J1-12R (RED) This is main power feed (hot at all times) coming TO the ignition switch from the ammeter circuit IT IS NOT FUSED
E2-18O (Orange) is dash dimmer controlled lighting for the **** quadrant
M16-20BK (BlacK) I believe is for the "key in" switch
i emailed him the factory electrical pages out of my 74' manual as a PDF after i first posted.GEEZUZ KRIST PEOPLE. I'm an old man and when I started screwin with this stuff THERE WAS NO INTERNET. THERE WAS NOT FREEKIN TEAM TO ASK "for free." YOU FIGURED IT OUT ON YOUR OWN or WENT TO THE DEALER AND BOUGHT YOURSELF A SHOP MANUAL
i learned by reading them...all the time. when i got my 73' challenger in the 80's, first thing was get a shop manual and learn to read it. if your willing to tackle a full re-wire, you have the capability to read one...Problem is most people starting out cannot utilize wiring diagrams and even some service info due to experience level.
Certainly. Yeah I pm,d him reference materials as well along with some long winded explanations , it'll all work out . How can it not with the wealth of experience here right!i emailed him the factory electrical pages out of my 74' manual as a PDF after i first posted.
he'll learn
