Where to purchase NEW 3rd member & Axles
johnmucci
moparmucci
Davenport Florida
Ok, I have a problem with my rear end, if needed, where can I buy a NEW punkin w/ sure grip and ring and pinion already set up and/or new a body axles small bolt pattern.....??? i am not buying anyones junk anymore!! i keep getting screwed!!
thanks!!!
DoctorDiff........
have bought 4 sets of axles...ring and pinion...spool ...bearing....and other parts....and always gets it right the first time..
I agree with both responses above. Randys sells good quality parts. I am running their 8 3/4 clutch type suregrip and I got a set of Yukon axles from Dr. Diff. He has very good prices also. He knows his stuff and is easy to deal with. When I ordered the axles I told him I had an A body 8 3/4 with 11" brakes and he knew exactly what I needed. He has sale ads on here but if you don't see one just send him a pm and he will send you his number.
Sounds like you're jumping the gun on this one. You just had the rear assembled. Did anyone verify the condition of the pumpkin or just dropped it in?
They're not that hard to setup on the bench. Maybe just have it pulled & setup right. These days you can nearly build a dana for the cost of a new pumpkin.
