69B-Cuda
So... last night, I was sealing up valve covers and dropped my socket when tightening the rear bolt on the drivers side. I listened carefully for it to hit the floor but, alas.. it got hung up somewhere! I moved my light to where I could see down along the driver side of the engine and it had fallen right on top of my starter, I could see it, no problem. When I reached down to get it, it slipped and dropped out of sight but again, it never hit the ground. I thought maybe it was sitting on top of the starter and I just couldnt see it so, I pulled the starter out
no socket anywhere to be found! I am running an MSD mini starter and it does not fill up the complete hole in the bellhousing! The socket slipped into the bellhousing DOH! I pulled the inspection cover off and there it was laying on the bottom right in front of the torque converter. Im glad it did not drop behind or get wedged in the starter ring teeth
that could have been WAY BAD!
What's some more strange places you guys have dropped stuff and had them land?
