Hello,
I am trying to install my fuel line back in my 72 Demon and am having an issue with the ebrake tension rod which actually intersects with the fuel line under the passenger seat. I am trying to figure out if the fuel line goes over that rod or under that rod. Can somebody check their original 72 demon and let me know which it is? I am guess that the fuel line should hug the floorboards and the ebrake tension rod should go below it, however they seem to rub each other? Does yours rub the rod or is there an air space that is suppose to be there? I don't want to create a fuel leak.....
