'68 Dart. The service manual says to install a "rubber asbestos" gasket on the axle housing studs as the first gasket prior to installing the brake support plate. The gaskets that I have are thin steel (look like powder coated???), not rubber asbestos. Fel-Pro #55032 (aka 15-1008). Is this the right gasket to go between the axle housing and the brake plate? Then, the foam gasket goes on after the brake plate, correct??
