Which rear springs and shocks?
71blueduster
Hastings, Nebraska
Looking at the Mopar SS springs to raise the rear of the car for more tire clearance. Looking at Summit's catalog they have the 002/003 original 1968 Hemi SS springs or the 865/866 3300 lbs springs. I was wondering which ones would be the best choice. The car is a 71 Duster 340/727/8-1/4 that I would guess weighs about 3200 or a little heavier. Car is street/strip and I need to get some traction badly. I'll be getting some drag radials later on also, but the tires rub with the stock springs if I hit a big bump in the road.
Also what else new hardware should I get with the springs? And what shocks are everyone using with the SS springs. I have some cheap Napa shocks there now and would need extended ones for the new springs anyways.
Thanks for the help.
I have 002/003s and MP long shocks on my car. Make shure you buy new U bolts and a rear shackle kit. Makes it much easier.
Mancini Racing gives you a choice of one or the other free with a set of new springs.
Is moPar still having the Mexicans make springs with that metal?
Mine sagged quick. Totaly worthless in 2 weeks.
Go here; http://www.espo.com/
I have the HD MP springs in my Dart, and they are still solid, and they've been on over a year now.
I have the 002/003 springs on the back of the Duster. I didn't like the stink
bug look. So I flipped the front spring mount. Brought it back to about stock
height. Use plain gas charged shocks on the back. And Summit brand adjustable( 90/10) drag shocks front. Car lunches very well. I was able to put
255/60-15s in the stock wheelwells. Just my way of doing it. Pics of the stance is in my photo garage.
What weight are the P/N 3412002/3412003 springs for? I bought em' so long ago I forget...
I'm not dead sure on this because it's been a while since I read it. But *I do believe* it's something like 2600 - 2800 lbs. Or in other words, a lightened A body. Done right.
I did mine exactly as briankaplan describes, 255s and all. Looks stock, everything fits well but tight and meaty if you look closely. As it should be, IMHO...
I installed the 002 and 003 springs on my 68 Dart GTS 340 and found all the front and rear mounts were rusted away. I replaced them with pieces I bought from Laysons. Be sure to check yours. The biggest tire I could get under my car was a 235/60/15. Be sure to check the back spacing on the wheels you have or want to buy. I saw a 70 Dart with 255 on the rear using rally wheels. Jeff
this is my 74 duster with the 002,003 super stock springs. the tires on the slots are 295-50-25 tires which fit completely in the stock fender wells without hanging out the side. the rallys are 255-60-16 bfg ta. the ss springs give the car a very nice stance without adding air shocks.
