Which rings for kb167
sublimeswinger
SUBLIME Senior Member
Santa Clara,CA
Im getting my machine work done. The teen will be 30 over and i will be getting the KB 167 pistons. I need help with the rings? can someone give me a part # that will work.
I don't know, but I can call my supplier and have them shipped to you today if you want. I just need you name and address in a PM and payment arrangements and they'er yours. They would run about $30.00 or so + shipping.
That sounds right for them.
I would otherwise use zero gap rings. But they are very expensive by compare. I have never had a problem with Hasting rings before. I have used them several times without issue. Moly's!
Summit should be able to hook you up wirh some decent rings. Hastings, Speed-Pro, TRW etc... Just order the moly ring for your bore (3.94 on a .030 318). When you install the rings, set the end gaps according to KB specs. The KB piston specs a larger top ring gap due to higher placement on the piston (it runs hotter).
