would like to find out who on FABO would be the Edelbrock guru to help with calibrating my Thunder Series 650 carb. Thanks,Bill
I broke down and bought a vacuum guage today. being old school I have never used any gauges or timing lights or anything like that. I never used anything on Tylers 360 and it runs great. But this damn 440 with this cam in it is making me old. I set the timing with it and it doesn't like it where it says it is supposed to be. I advanced it where it ran the fastest and backed it off I inch. took it out for a drive and it pinged like hell. brought it back and put it back where it was at. runs and starts good. I changed the setup springs down to orange and it surged a little when it was at a constant rpm. so I brought it back and put the pink back in. I read in the Edelbrock manual where if you have a bigger cam and low vacuum that you may have to run the pink or silver spring. This car for some reason likes the pink spring. Have a 509/292 purple cam in it. I have between 5-6 hg of vacuum at idle according to the guage. I set the idle up a little. I adjusted both A/F screws and it likes them about 1 1/2 turns out. That is just about where the guage peaks. The problem I am having now is when I drive down the road and slow down to make a turn into a parking lot, it seems like the engine wants to stall. I didn't mess with any jets or metering rods. I did move the accelerator pump linkage to the top hole. It came from the factory in the middle hole.
what would cause the engine to act like it wants to stall when making a turn into a driveway or parking lot. This is a Thunder Series 650 CFM AVS carb. Practically new carb. Other than acting like it wants to stall, this thing runs great. any suggestions. Before you suggest fuel pumps, filters and all the other stuff, it didn't act like it would stall till I started messing with the running rich problem here. Would moving the accelerator pump linkage do this. suggestions appreciated. Bill
I moved the linkage back to the center hole. I have not verified the float levels because the top has never been off yet and it didn't do this before I started changing things so I didn't see any reason that the floats would have changed. But I guess I will have to check this. I think Edelbrock says that there should be 7/16 " on the float. How accurate should that be. should I set them higher to allow more fuel in the bowl , maybe 3/8 or so or just the 7/16.
