Who makes an Aluminum master cylinder for 70 dart front manual disc brakes
73dart360
fort lauderdale
Looking to upgrade master cylinder hopefully one that wont leak down onto new paint
70 dart front manual disc any suggestions please . ?
You'll need the correct 2-bolt adapter to mate a later model aluminum master cylinder for an F-body with manual disc brakes. It still uses the manual brake pushrod. Not sure how or which distribution block fits into the set-up
F- body master cylinder and adapter plate. Cheap, easy, and all MOPAR
Wilwood sells a nice one.
Can also buy one for 85 diplomat but that's s crap shoot because a lot of them aren't alum. When I was looking I found one alumn local to me and it was all beat to hell.
Does aluminum not leak? I am going through it now, nice paint on firewall ruined because of old style cast iron MC. The MC isn't that old either.
The cover on the "billet" Willwood m/c leaks around the screws. Those tiny screws are easy to drop/lose. I am replacing mine with a Baer m/c which has normal screw-on caps.
thats a wilwood one in this pic.. it has a different piston size then the billet one you are talking about i believe..
Ah, yes. I forgot Willwood sold those too. My preference was to not have the plastic tank. But you're probably better off with the one you got. The billet one I have s nothing but a pain in the ***!
Dr Diff sells an adapter plate + MC for ~$95. Has been linked several times in the last 2 months if you search. He recently chimed in that his are specially made w/ a smaller bore (7/8"D?) than the similar-looking 1980's Dodge truck MC. Or, for $30 you can buy an adapter plate on ebay from several sellers and use almost any 2-bolt aluminum MC. I use one for a 95-99 Breeze/Cirrus/Sratus w/ ABS (7/8" bore) on my 3 1960's Mopars [two via adapter plates, one on a Breeze booster (see avatar)].
